RWKHausSupply
- yorba linda, Cali
I have a 1998 TJ (same engine as a XJ) with a nice very clean 4.0. Jeep has 155k miles total on it and if you see the jeep and powertrain, you will believe me when I say it was very well cared for.
I will be removing the engine in it, hopfuly in about a month. I would like to find someone that wants/needs a nice used 4.0. Someone that wants to hear and drive the jeep even, to know what they are getting. It has no oil leaks, no smoke, no damage, no noise, etc. It is in excellent condition.
I will be including almost a complete engine. Few items will be still on the engine that typically are not.
Includes:
Valve cover to oil pan and everything between (Long block).
Timing cover
Intake manifold
Exhaust manifold
Most intake and engine sensors
Coil bracket and coil
Distributor
Water pump
Poss fuel rail
Fuel injectors
192temp high flow robertshaw t-stat
new t-stat housing
dip stick
$900
Located in Yorba Linda
This picture give you an idea as to how clean the engine and well taken care of the jeep/engine was.
Includes:
Timing cover
Intake manifold
Exhaust manifold
Distributor
Water pump
Poss fuel rail
Fuel injectors
new t-stat housing
dip stick
$900
