I'm selling one of my jeeps because I need to come up with extra money for the down payment towards my first home.
The specs are
1998 cherokee 4 door
4.0 inline six engine
4 speed automatic trans with overdrive (AW4)
NP231 transfer case with 2.72 gear ratio
High pinion Dana 30 front axle. 3.55 ratio
Chrysler 8.25 rear axle 3.55 ratio.
The good stuff
AC blows COLD
HEAT keep inside TOASTY in the winter.
Solid diff covers on both axles
New head gasket
New valve cover gasket
99+ intake upgrade
Ford #700 injectors
New radiator, water pump, and thermostat
Auxiliary fuse panel with 4 circuits
7 slot switch panel with 4 switches and rare ext. idle switch
ZJ seat conversion in front/rear
Overhead console
Ares Fab front bumper with tie in plates
Solid steel steering spacer
New track bar
Extended shackles in rear
Axle joints were replaced
30" tires on TJ canyon alloy rims!
Interior LED light upgrade
New alternator
New battery
New starter
New battery cables (4 gauge)
New fuel pump
Cruise control
99+ dark interior swap
Headlight harness upgrade
I also have a 3.5" lift kit that I ll include for $300 more
The bad?
It need a headliner (previous owner ripped it out because it was sagging)
The locks sometime work
Low compression in #1 cylinder (worn out rings)
Description;
I daily drove this jeep even with the low compression ever since the day I bought it. Never had a problem with it. Runs strong. I put 10,000 miles o it since I bought it.
I would prefer to keep it and finish the lift but the house purchase comes first, so I'm reluctantly selling this.
$2,000 or best offer.
The specs are
The good stuff
AC blows COLD
New head gasket
99+ intake upgrade
Ford #700 injectors
Overhead console
New track bar
New alternator
New battery
New starter
New fuel pump
Cruise control
The bad?
Description;
