1997+ Body Part Out and Misc Parts (XJ ZJ YJ)
LessThanJoe
Boston Area
(Will be away on vacation from 8/20 - 8/26)
1997 Body Shell Partout - Interior totally stripped, no wiring. Shell has a clean NJ title. Rockers have rust, as well as rear quarter panels. Was hit in front drivers corner. No header panel. Rear windows tinted. Body has a sunroof installed. Leaks. P/O had it sealed up with caulk. I was going to repair but then accident. Ask for information or pics on any parts.
Picture Album
- Google
Pickup in Hazlet, NJ - Smaller items can be shipped
All 4 doors available - Window motors (except driver) and all door lock actuators bad. No rust on doors. Doors and tailgate have matching key.
Tailgate - Tinted glass with defroster. No wiper motor. Clearcoat on top edge is flaking.
Hood - Clearcoat flaking off, front driver corner has slight damage.
Driver fender - Red - No dents or rust.
Pass fender - Green - Clearcoat peeling from top edge. No dents.
Rear bumper with endcaps. Still attached to body. No dents
Front bumper with brackets - No endcaps. Has center air dam. No dents.
Front D30 (3.55) Possible damage from accident.
Rear 8.25 (3.55) No brake parts included besides backing plate and drum.
Misc Parts XJ
97 Gas Tank with pump
(2) Gas tank side shields
(2) 97-98 Intake Manifolds w Fuel Rail
Oil pan - Light rust
Valve cover
4.0 Flex Plate
Mechanical Fan
Fan Shroud
Trans Crossmember
Radiator - 2 Row w plastic tanks
Stock downpipe (non-cali)
Rear soundbar - fabric loose
(2) Full Spare tire cover (grey)
Coolant overflow tank
Washer fluid tank (no pumps)
(2) Ignition coils w/bracket
Front and rear wiper arms
4.0 AW4 Cooler Lines
Battery Tray (cut to fit size 34)
PS Pump and Steering Box (200k miles)
Roof Rack and Rails
AW4 Dust Shield 2 Piece
Headlight Bezels - 2 Pass 1 Driver
Stock airbox cover
(4) XJ Stock Steel Wheel hubcaps
AW4 Tailhousings and speed sensors (1) 97 (1) 98
YJ Poly Gas Tank - Has dent (crack?) in lower corner, no leaks.
YJ Set 1.5" Superlift Springs - Driver Rear has 2 cracked leafs.
ZJ 4.0 FlexPlate
ZJ Mechanical Fan
ZJ P/S Pump
ZJ Waterpump
700R4/4L60 5 Bolt 4WD Tailhousing (Chevy 231)
700R4/4L60 6 Bolt 4WD Tailhousing (Dodge 231)
NP231C Front Case Half (5 bolt - Match with Tailhousing above for 4wd 700R4)
