043500
- Ocala, FL USA
I need you to look something up for me. My 1994 service manul includes the XJ and YJ...what I need is for the YJ motor.
I'm running a 1994 YJ 2.5L engine and wiring harness.
We went to crank the motor tonight and we are getting code 54 (I believe) which is CAM position sensor. We finagled some things and got it to run BUT after shutting it down we could not get it to start again.
What we need you to look at are the 2 "engine connectors". They are the 16 pin connectors that go between the PCM and power dist block and I believe the interior harness.
We need you to look at the manual AND the actual connectors to verify all the wires are in the right color/sequence.
In my 1994 manual this is on sheet 69 for the YJ wiring diagrams...the 4.0L and 2.5L are listed together BUT it;s easy to distinguish. So if you could just run down the list for both connectors and tell us what the color codes are for each of the 16 pins it would be much appreciated...AND if you could verify that they are the same under the hood. Again this is for the 2.5L engine.
We think we ended up with a 1995 power dist block and there are about 3 wires that don't match up between it and the 1994 harness...so if we can trace them we can re-wire them correctly.
THANKS!
THANKS!
