1993 Ford F-250 4x4,Diesel 7.3 IDI non turbo,supercab longbed XLT or Trade for TJ-YJ
XJNASH
Shreveport, La
1993 Ford F-250 4x4 Diesel 7.3 IDI non turbo supercab longbed XLT
$6000.00 obo
New Transmission as of 5/29/2007
Following items have been repaired:
* New joints and u joints in front axle 4495gwv
* New American Racing Atlas Rims 16x8
* New Alternator and battery's
* Stater rebuilt all new solenoids, Key switch and lower switch
* Kenwood Cd Deck
* New Joints in rear drive shaft
* New Break Master Cylinder and booster
* New Rear wheel cylinders
* New Front windshield
* New 2.5 Lift from Tuff country
* IP rebuilt and turned up
* Replaced valve cover gaskets
* CDR valve
* Turn signal switch
* New steering pump and gearbox and outer driver tie rod
* New door window motors
Truck has 265/75 16 AT tires, 4x4 works, Has been aligned with new lift, Has goos neck setup, Drop hitch, has E40D Trans, also comes with trailer break controller.
It has a slight oil leak on the cooler side which I haven't gotten around to and need a new drivers seat cover and leather wrap on the steering wheel. It as 255,688 miles on it. I'm the third owner title clear. drives straight and I drive it to work daily which isn't about 4 miles from my house. Also the AC works and Heater work great! Truck is white with Grey interior.
I have all the paper work on the Injection pump and Transmission rebuild.
I would also concider a trade for a Ski/fishing boat.
pictures can be seen at www.nashsystems.biz/f250
