jeannies_driver
- Drumore, Pennsylvania
Moving once again so it needs to go.
1990 XJ 4 door with title Stock engine and tranny.
231 case w/SYE kit
Quigley 4x4 drive shafts front and rear
HP Dana 30, welded 8.25 rear
Yukon 4.56 gears
Yukon 29 spline rear shafts
Nitro front shafts
Jaz 22 gallon fuel cell w/rollover valve, 45* filler valve and remote fill tube
Walbro GSL-392 fuel pump
EMPI Suspension seats
G-Force 5 point harness
1.75x.120 cage
1.50x.120 supports
Clayton pro series 3 link
Clayton 6.5" rear springs
Allied wheel RT 8178012 17" steel beadlocks
All new bearings, seals, hubs, rotors, drums, calipers, hardware etc. on the axles.
Tera high steer knuckle
Ruff Stuff 1 ton steering ends
Ruff Stuff diff covers
Wiring harness stripped and partially installed
Cage is about 90% complete at this point
There's probably more I'm forgetting to list.
Everything on it is brand new never used !
$6000 as is buy it now price.
I have around 10k in parts alone with receipts.
If you want it running and driving ready to wheel I can finish it for a little more money depending on parts.
Some pics, http://s161.photobucket.com/albums/t232/jeannies_driver/KOH Build/?src=wap
If you want pics of anything specific or more info let me know.
Located in Drumore Pa. 17518
231 case w/SYE kit
Yukon 4.56 gears
Nitro front shafts
1.75x.120 cage
1.50x.120 supports
