addction
- Wentzville Mo.
Jeep body from Copart with auction fee’s $430
Rustys Long arm lift kit Part # 800LT $2080
Over the Knuckle steering Kit Part # OTK 01 $550
Drop Pitman arm Part # DPH 01 $189
Slip yoke Elimator kit & TW Driveshaft Part # AAcombo1 $540
JCR front bumper with Drings & unibody tie-ins $390
Wheels Type 51 D window Black 42 each (4wheel parts) $168
BFG MT’s 33x12.50x15 155each (auto tire) $640
Lock right Locker Front axle locker (4wheel parts) $225
Aussie Locker Rear axle locker (ebay) $245
8.8 ford explorer axle (from midwest auto recyclers) $450
4.10 gears for 8.8 (ford racing) $167
MORE antiwrap spring perch’s & 1310 yoke $80
4.10 gears for Dana 30 & open carrier for 4.10 gears (Dana) $194
Front stub axle’s 4140 (ebay) $210
Inner axles (Jeep ZJ 297 joints from riverside auto) $50
Stroker 4.6L motor $2200
4.2L crank turned .10 X .10 and rebalanced
4.2L Rods shot & magnafluxed
40 over 4.0 pistons (10-1 compression)
1990 block bored 40 over & new cam bearings installed
1994 head (7120 casting) 3 angle valve job
Hastings rings
Cleveite 77 bearings
Comp cam
Comp lifters
Comp springs & locks
2000 Jeep intake manifold & power steering pump & brackets
24# injectors (ford racing)
Melling high volume oil pump
New Harmonic balancer
New starter
New water pump
New spark plugs, wires, cap & rotor
New Jeep crank trigger
3” Flow master (super 40) $82
New battery (auto zone) $45
Rock sliders & Rear Bumper w/tire carrier $300
$9235 Invested, This Jeep has not been off road yet. And the motor only has 100 miles on it. It's a great jeep, but I just Dont need 2 of them, So the first $5500 takes it!!! I buying a 350z roadster so could use the money for that. Call Joe @ (636)332-1880 or (636)357-0398
Hastings rings
Comp cam
Comp lifters
New starter
New water pump
