1990 XJ - 5.5" lift, 35's
iispms
I am thinking about selling my 1990 Jeep XJ Limited. It has had the following done to it in the past 2 months:
5.5" Extreme RE lift
heavy duty trac front track bar
Old Man Emu Shocks - back are for Grand Cherokee (Longer)
NEW 2000 8.8 rear axle with disc brakes
4.88 gears
ARB Lockers front and back
HPD30 upgraded with 297 shafts (hardened)
35" GY MTRs (70-80% tread left) on 15 x 8 Aluminum Rims
NEW 35" spare on black steel rim
Fenders well trimmed and welded
Roll on Bedliner from the pin strip down
Rear main seal replaced (1000 miles)
All fluids changed (less then 1000 miles)
231 T-case with AA SYE Kit
Tom Woods Drives shaft
New Front Brake pads and Rotors
JKS Discos
All of the above was done in the past 1000 miles. It has only really been driven in the Jeep Jamboree 3 weeks ago at Tellico.
127,xxx miles. The motor runs good. For some reason, it shifts at 2800 RPM no matter if the gas is floored or driving normal. It has an AUTO tranny. Other then that, it runs great. No smoke or oil consumption. The air conditioner works and blows cold. Motor is a 4.0L 6 Cyl.
I have more pictures, bigger too! I want $6,000 for it. It is located in New Orleans. I would consider trades/partial trades of a short wheel base chevy pickup.
Chip
[email protected]
Since I cannot post pictures, email me and I will send them to you.
