grimah1w
- Woodlawn, TN
Engine shut down and accessories turned off (died) while driving. Complete failure of electrics powering ignition and accessories. Lights work fine, hazards worked..even dome lights light when door opened. replaced ignition switch road side...did not fix. fuses on fuse panel driver side lower are all ok.
accessories will not power--blower motor, radio -- nogo
ignition -- no power
start -- no power
buzzer for key in ignition works.
lights work
fog lights work
dome lights work
door locks work
smelled like burned electic component when it happened...driver side interior
thought that ignition switch may have failed..replaced but did not fix problem.
searched but got random returns mostly to do with partial engine power or windows/door lock not working...
ideas?
start -- no power
lights work
fog lights work
dome lights work
door locks work
ideas?
