Redrockracer1019
- Sedona
Hello.. I'm a new member to this sight. I'm not a complete idiot. I've been a jeep tour mechanic for the past 6 years am performed alot of messy jobs on the TJ an jk platform.. My rig is a 1990 mj Comanche... It has a aw4 4x4 an np231 correct?
I resently purchased a rolled 2wd 2000 xj with 120k miles started right up after I wired up a fuel pump out of a bucket...
I've began to swap the 4.0HO in to the Comanche taking the dash completely out guttin the engine bay.. Plan to put the xj dash an all engine bay wireing in..
My question for you...as I want to retain 4x4... How do I wire up the aw4 to the controller.. Should I keep the 90 controller an trans harness? Or attempt to change the sensorage wireing at trans with the complete Cherokee harness an run the 2000 aw4 controller? Is there an easy way...? Thanks
:clap:
:clap:
