COWBOYJIM3
- frisco, tx
I have a 1990 that wouldnt start. I recently replaced the spark plugs and it ran great. the next day it wouldnt start. I was not getting any spark. i changed the ignition coil and it didnt fix. so i put the old one back on and researched further. i replaced the crank pos. sensor and the jeep started easily. after starting it a few times in an hour i began to drive it. i turned on the headlights and the engine sputtered and died. At that point i started it and as soon as i put it in gear it died. after towing it home it will crank but not start. Once again it seems as if im getting no spark. After changing the CPS I noticed I had no battery guage, temp guage or oil pressure. I had the hood all the way up when i was changing the CPS and it started raining. PLEASE HELP...
