1989 XJ for sale
brokexj
NAXJA Member #1165
TIDEWATER!, VA
1989 Jeep Cherokee,
Black, 98 fascia, tinted windows; body has bed liner from the body line down. Grey interior, limited leather power seats in decent shape, full gauge cluster and CB installed. Pontiac hood vents installed. The front bumper is an Olympic with Warn M8000 with wire rope, having a problem with the solenoid pack, will only power in. Rear bumper is a homemade.
151K on Odometer, engine replaced with 96 HO with 66K, Renix FI with intake tigged to have ports match up, open cooling system, Accel 8.8 wires, bored TB with Air raid intake tube and K&N filter. Injectors are 2 years old. AW-4 Auto, 242 TC with H&T SYE with correct rear DS, u joints replaced and flange replaced with one trip. Mobil 1 synthetic oil, new fuel filter. Full exhaust with cat and flowmaster.
Front axle: 76 Ford HP44, narrowed to Wagoneer width (62.5” WMS-WMS), Warn chromo axle shafts (inner and outer) with Spicer 760X’s, Rubicon Express bracket kit, front diff guard, Aussie locker and u bolt yoke. Gm knuckles with High steer, All new 1 ton TRW TRE’s, Shaker built Tubes, TRW ball joints, no sway bar mounts, Durango steering box, Warn premium lockouts, 4.10’s with 5x5.5” BP This axle has the mounts for a four link.
Rear Axle: 95 8.8, Limited slip, 4.10’s, Crane rear cover, raised shock mounts, rear disc’s, new bearings installed 3 trips ago, spacers to change BP to 5x5.5”.
Wheels are 15x8 razor Aluminum wheels, MT Baja Claw radial’s 35x12.50x15 60%-80% even wear, with matching FS spare.
Suspension: RK 3 link front, RE monotubes, SJ 6” coils, Rusty’s 6.5” rear leafs with TNT 1” Boomerang shackles. Warn transfer case skid.
This XJ has wheeled Crozet, Paragon, and Uhwarrie.
Comes with spare lockouts, spindle, bearings, 1 outer shaft, front DS.
Jeep was laid on the PS and creased the "B" pillar above the hinges.
$2700.00 Located in SEVA.
http://s200.photobucket.com/albums/a...view=slideshow
