1989 Jeep Cherokee - Parting out
twmart
I have a 1989 Jeep Cherokee that I am going to part out. The Cherokee only has 188,000 miles on it. This is a complete running Cherokee everything works I bought this for parts to fix my other Cherokee. We have been driving this for the last 3 months and never had any problems. It has cruise control but the steering wheel switch was missing some never could test it.
This Cherokee had the 4.0L Renix Engine automatic, 4 wheel drive, Gray cloth interior.
The following parts are sold or not usable
- Windshield - Cracked
- Engine Long Block - Keeping
- Tires and Rims
- Spare Tire - Missing
- Dash - Busted
- Brake Booster - Going out
- Grill - Sold
- Bumper and Push bar - Sold
- Rear Bumper - Dented (Sell Real Cheap) no end caps
- Rear Dana 35 - Pending Sale
Here are some of the parts for-sale, like I said this is a complete running Cherokee so it still has every part still there.
Front Dana 30 CAD Axle - 3:55 Gears $175.00
Rear Dana 35 - 3:55 Gears $200.00
Front Drive Shaft $40.00
Rear Drive Shaft $40.00
Front Coil Springs Stock $10.00 pair
Rear Leaf Springs Stock $20.00 pair
Aw-4 Automatic Trans - 21 spline $225.00 No leaks
NP231J Transfer Case - 21 Spline $200.00 No leaks
Complete A/C System $5.00 and up depending on the part or Complete System $150.00 A/C was working great until I had the freon recovered last week.
Power Steering Gear Box $50.00 Works good no noises or leaks
Power steering pump with bracket and hoses $50.00 Works good no noises or leaks
Steering Column $50.00
Steering Wheel $25.00
I will be selling all of the engine parts that I do not need such as the following plus more;
Intake Assembly Complete $120.00 Includes the Intake, injectors (with NEW o-rings), fuel rail, pressure regulator, thottle body with sensors. The only part not included is the IAC
Intake $40.00
Fuel Injectors $10.00 each
Fuel Injector rail $10.00
Fuel Pressure Regulator $10.00
Throttle Body $40.00
Sensors $10.00 each
PCM $40.00
Engine Wiring harness $20.00
Exhaust - Head Pipe, muffler with free CAT, tail pipe
Flexplate $40.00
Valve Cover $20.00
Harmonic Balancer $20.00
Radiator $80.00 ALL BRASS not aluminum and plastic
Heater Control Valve $20.00
Motor Mount Brackets (mount to engine) and (mount to Frame) $10.00 each
Air Box $20.00
Air tube $10.00
LH HeadLight Bezel - Chrome $15.00
RH HeadLight Bezel - Chrome $15.00
Hood $40.00
Rear Lift Gate $50.00 With glass (defrost) and wiring - No wiper motor
I am located in Broomfield, by 120th Ave and Federal.
Click on Thumbnail to view larger image.
vacuum bottle? shipped to 88220?
Condition of headliner? Condition of front carpet?
I am interested in the drivers seat bottom cloth. IF not in good condition, then the passengers seat bottom cloth.
Cost on these?
PM with details or call
Tom Houston
970-391-8927
Updates
Brake lines came out without being stripped
All glass is good (except the windshield)
Parts sold today..
Power Steering Box
Power Steering Pressure hose
Exhaust system
Did not read this soon enough :eyes:
I already got the engine ready to pull tomorrow morning, Trans and all. Just need to pull driveshafts and drain fluids and pull it.
You have a cherry picker?. If not give me a call.
Look at the pics ya tard....... See any cranks???? :twak:
:D
LOL now thats funny:roflmao:
Yes they are power windows Or they can be door shells real quick and you could put in your manual regulator.... Then yes it would be manual and not power :eyes: :guitar:
Engine gets to come out tomorrow and then will have the AW-4 and NP231J 21 Spline available
Sold the Main rear brake line
As of today 9-11 The following parts sold;
All 4 doors I still have 3 off the Blue 1996 full power
Rear Hatch
Drivers side Hinges
Hood - I do have 2 that need paint for $20 each
Headliner and Carpets promised to board member
We are starting to CUT up the body Tues or Wed so if you need a Roof, Rockers or Rear Quarters let e know ASAP.
Tom
Thanks
Tom
