Ecomike
NAXJA# 2091
- MilkyWay Galaxy
1985 Cherokee Pioneer, 2WD, Base modle.
I have isolated my remaining heavy battery drain problem to the running lights wiring ( I disconnected the other parts that are no longer used anyway), and when I disconnect the running lights power source wire at the battery I loose running lights, and I loose the short/load killing the battery.
But with it connected I have no running lights with the head light switch off, and they work with the HL switch on, for head lights or just running lights (which is normal). With the wire disconnected at the battery I have no running lights at all on any HL switch setting.
BUT!!!! The shorted load is less (or zero) with the HL switch on for running lights or head lights, than with it all the way off? In other words, The parasitic load killing the battery is largest with the head light switch off. I think the short is only when the head light switch is all the way off.
Could the head light switch be shorted out in the off position internally? I have never seen or heard of this, but maybe others have???
