devildog0
- Hunt County Texas
Just picked up a CJ5 a few days ago.
1976 CJ5 with a 304 V8, T150 3-spd transmission and a D20 Tcase. It needs some TLC but I've began the process of getting it back into shape. It does run and drive as of right now but has a little bit of rust in the floor boards and windshield frame and I'm wanting to take it back to a more stock condition vs how it is now. The brakes are also in poor adjustment resulting in pulling hard left and even locking up the left tire under even moderate braking. The steering is in need of a refresh, the steering shaft has a lot of play in the upper u-joint and the collar (not sure what it's called) just above the U-joint. And the carburetor has a pretty bad fuel leak but fuels well.
The POs did some pretty janky wiring on the Jeep as well and modified the stock bumper in various ways. Including welding supports to the frame which I'm going to have to get creative with a cutting wheel to get loose.
Anywho I'm glad to find this forum and hope to be able to come here for help in the future on this project.
This morning I got up and busted out a few hours of work getting the interior ripped out and a few other odds and ends removed like the home made roll bar and the rotting windshield frame. One of the POs did some "interesting" wiring on the Jeep. Should be a fun project and not too much effort to get back into decent shape. Biggest stuff I think is going to be the rust repair of the floor board and rocker panels.
End goal is to get it back pretty close to stock.
Last night when I shoehorned it into the garage.
Janky previous owner wiring
That's 3 self tappers in the frame to ground a set of LED podlights
Lift shackles. Those are going away and the suspension will get a full rebuild.
Previous owner wiring to make the LEDs work
Windshield frame rot
Most of the interior out. I pulled the roll bar and wheel well carpet right after this photo. Roll bar definitely looks home built/welded.
Passenger floorboard rot
Driver's side not as holey but still kind of bad.
Tried to salvage the windshield and botched the removal.
Shedding rust from messing with the windshield frame
It had some diamond plate rocker covers riveted in place. I drilled the rivets and found what I expected. Same spot on both sides.
Underhood the wiring is a bit of a mess and the airhorns are going bye bye. Powertrain is AMC 304 V8, T150 3 spd manual, Dana 20 Transfer case, Dana 44 rear axle and Dana 30 front. The transmission needs an overhaul, it won't stay in first gear unless you hold the shifter in place. And the Transfer case has a pretty stout leak from the rear output seal. I'll probably overhaul it as well while I have the transmission out.
