- sacramento
Selling the willys.
1959 jeep Cj5 willys
2 most common paperwork questions:
Yes its currently registered(no back fees)
yes pink in my name, and i do have it in person ( hate going to look at a jeep then find out it has tons of backfees and no pink)
Engine/tranny/tcase
ford 2.8 v6
t90
dana 18
hydraulic clutch setup with 1980 CJ5 master and slave
new clutch disc, resurfaced flywheel, and pressure plate, and throwout bearing, all done at capital clutch and brake
electric fuel pump conversion
all new oil/temp/amp/speedo gauges
Drivetrain:
swapped in :
front late 70s narrow track dana 30 swap with disc brakes, chromos, 4.88s, all new seals and bearings, and a lock right locker
rear later dana 44 with the bigger rear drums, semi floating (non tapered rear end, way nice)
heavy duty differential skids on front and rear diffs
all new brake hard lines and brake soft lines
newer jeep cherokee brake booster and brake master cylinder
thing stops on a dime
ignition :
ford duraspark ignition
new ignition coil
new cap and rotor
new plugs and plug wires
rebuilt motorcraft 2100
wrapped fuel lines in heat tape
oil change
cooling system flush
new radiator cap
steering and suspension:
sagniaw box with power steering conversion
2.5" lift with 31" mud tires (95% tread)
power brakes and power steering
Bilstein 5100s in the rear
pro comp charged shocks up front
1.5" DOM steering with hems
new front leaf bushings
replaced rear leaves with brand new 2.5" leaves
Interior/exterior:
has a working heater
New exterior Paint (burnt orange)
new side marker lights
new interior paint(orange and black)
welded up a steering stabilizer
6 point roll cage
heculined interior floors
new seat covers
really nice looking rear seat with built in lock box for spare parts
cd player with headphone jack (iPod hookup)
new rear light bulbs
cons:
doesn't have a fuel gauge. It didn't have one when we got it years ago, and we recently bought one that might be in the right resistance range, but haven't wired it up yet. Ill try to wire it up before a sale .
5200$ obo
ill post pics later, i can text pics for now
Engine/tranny/tcase
ford 2.8 v6
t90
dana 18
Drivetrain:
swapped in :
ignition :
new ignition coil
new cap and rotor
oil change
new radiator cap
Interior/exterior:
6 point roll cage
new seat covers
cons:
5200$ obo
