18v snap on impact gun.
YeaItsSlo
New Haven,CT
Features:
* Patented impact mechanism delivers power and durability.
* Patented air flow system keeps motor cool for longer life.
* Heat-treated alloy steel gears.
* Cushion mounted motor dampens vibration.
* Alloy steel driveshaft bushing.
* Soldered terminals have greater strength and conductivity.
* Soft grip handle.
* Rugged housing helps prevent damage from dropping & resists chemical damage from most automotive solvents.
* Balanced design.
* Conveniently located Forward/Reverse bar.
* UL Listed.
* EU/CE - DE, ES, FR, GB, IT, NL European models.
Product Specifications
Stock #
Name Impact Wrench, Cordless, 18 Volt, 1/2" Drive (U.S.)
Square Drive, inches 1/2
Tightening Torque, ft. lbs. (N•m) 210 (284)
Free Speed, rpm 1,950
Blows per Minute 2,400
Motor/Battery Voltage 18VDC
Battery Type Nickel-cadmium
Battery Life 600 cycles
Charge Time approx. 45 minutes
Length, inches (mm) 9.5 (241)
Weight, lbs. (kg) 6.5 (2.95) with battery
Battery CTB3185
Battery Charger CTC318 or CTC328
used only a dozen times maybe.. comes with a flip socket and extension.. brand new from snap on i think it was like $450.. 2 or so years old.. no need for it anymore.. would make a great tool for the woods! comes with case, charge, 1 battery, flip socket and extension. $250 OBO!
