12 volt compressor -- solenoid or relay?
jmg222
US
I have a 12 volt, 3/4 hp puma compressor in my cherokee I use to air up.
I currently have it connected to a solenoid, which is connected to a switch.
IS there any reason I need to use the solenoid, or to keep things simple, can I just use a high-amp relay?
A "solenoid" is a relay. If it works, and you understand it, don't fix it.
yeah, it works, I understand it, just trying to go a little more compact.
Duh on the current draw-- stupid me --- pump is drawing max 46 amps @ 12 volts... relay just won't cut it.
You can get high amp relay's. I don't know how much more compact they will be.
Couple here, more on their site then I posted:
https://www.waytekwire.com/item/75552/Bosch-Tyco-0332002156-Power-Relay-/
https://www.waytekwire.com/item/46095/EATON-s-Bussmann-Series-Power-Relay-Module-70A-/
