- Seattle, WA
I have the following stuff for sale that is taking up space and needs to go:
1) a pair of rear 30-spline D44 shafts. They will need new bearings presed on. I just pulled them and installed chromos. Splines and shafts are in great shape. Asking $75 OBO
2) a set of rear D44 disk brake pads. They are probably from Kragen or Autozone. Somehow I ended up with 2 sets and only used 1. Asking $30 OBO.
3) JCR 1-ton UTK setup with poly spacer. Some light rash from rocks, but in good shape. The drivers-side tie rod end was recently replaced. Asking $160. Knuckles need to be drilled and reamed to accept the larger TRE's.
4) Ford Taurus electric fan. Grabbed it from the junkyard planning on an electric fan swap but I am too lazy to get to this. Paid $45 at Pick and Pull, asking $35.
5) Front D30 disk brake pads, brand new in box. Basic pads from Kragen. Asking $30 OBO.
6) 1998 ABS pump. I pulled it when I swapped to my rear D44. Was in working condition when pulled. Asking $50 OBO.
7) Rustys Airtube for XJ and K&N cone filter. Asking $40 with K&N cone filter. Tired of swapping back and forth for smog. Also pulled my ABS pump and moved my ARB pump there instead.
8) Stock 1998 Infinity amp for stereo. Pulled it when I installed my aftermarket stuff. $10.
9) D44 rear disk brake backing plates. These appear to be brand new but do not have the dust shield. I got two sets when I bought my disk brake setup and I just don't need them. Get some pads, rotors, and calipers and you are ready for disk brakes. Asking $40 for the pair.
Make an offer by PM - worst I can do it reject it. All parts located in San Jose.
Josh the_weirdo
Josh the_weirdo
