mossyoakblack
- newton
Mossy
Hickory
98 xj 4.0
OK this isn't making any sense... Finally got my jeep running.. But it sounds like a subaru lol..
Meaning its missing really bad..
Number 1 injector is not spraying..a far as we know..
Tested with volt meter.. 12.5 volts to the power side of injector... And getting continuity from the injector pin down to the ecu as far as ground goes.. So I should be getting fuel right.. Also was getting p0201...
What's weird is with the noid light hooked up to the clip number 1 is the only one that doesn't light up..
I thought to myself lets say that the ground wire was grounding out some where before the ecu.. Wouldn't I then have a completey open injector? Even more wouldn't the noid light stay lit up?
Changed ecu and no difference... I'm stomped.. Any suggestions
Hickory
98 xj 4.0
