1.75 coil spacer
ebyrd10000
Phelan Ca
going to install a coil spacer and leave the stock isolator in do people leave the stock in place or install the 1.75 the the stock
It's about 50/50. Most of the spacer MFG say put spacer first them stock isolator them spring. This is to prvent the spring from dammaging th spacer. IMO it doesn't matter, which order you go, as long as the spring ends up on the bottom of the stack.
I ran spacer no isolator for a while. I didn't need the full 1.5" so removing the isolator trimmed it out nicely. Now I need isolators since I went to taller springs in order to ditch the spacers.
