1.5" SOLID dome tubing with 3/4 ton tres, NEW
Status
Not open for further replies.
desertjr
Low Desert
Tres are equivalent of the v8 zj tres which are m22 I believe. Link is 1.5" solid Dom tubing. It's an ironman 4x4 tie rod upgrade, brand new never mounted.
Cost was round 190 to my door, ill take 150 for it. It's 1.5" Dom threaded with a jam nut, and its solid steel.
These are beefy. Have one on my heep.
Ya it's a good 30+ lbs. I may keep it and have Andy machine it for currie tres..ill let Richard get back to me on my other head in mod tech section.
FYI... I dont see how you can get D.O.M. to be solid..
Look up what DOM means...
I bet it is heavy though lol
This the newer one with the machined ends for a wrench?
Bump ill take 125 for thats over 50 off what andy sells it for & no shipping. NEW never mounted, castle & jam nuts included.
Headed to the hammers? Bring some beef along with ya:)
New jcr 1 ton came in today. This single tie rod is heavier than the whole jcr setup lol. It's beef!
Ill toss is a semi-new drag link. 22k and a brand new moot tre, that goes to the pitman arm. So you'd have a complete steering setup:) bolt on and go!
Might wanna hold onto it, I heard those JCR kits have some killer tie rod roll on them, they have a huge dead spot in them. Inverted T's no bueno, but good luck with the sale of this tie rod if I had the need for such beef I'd get it
I have read that but it seems to be exaggerated at higher lifts. I'm only at 3". I also found someone used j series truck tre spacers, I'm hoping my low-ish lift and those spacers if I can find them will make it all good lol.
Status
