Fred85
- Orange, VA
I replaced my front axle u-joints this weekend. I also changed my front brake pads because the old ones were clunking when i hit the brakes (something i caused)
anyways, everything was put back together and all bolts torqued properly............but now i've got a "squeak...squeak...squeak..." as i drive. I'm also positive it's coming from the front end, and the noise completely stops when i hit the brakes. What could this be?
I found an old post by another late-model xj owner who said it was coming from his double cardan on the front shaft, he just greased the shaft up and the noise went away.
So i guess i'll grease the shaft up this weekend, is there anything else i could check??
