98XJSport
Destiny is the rising sun
- Western Maine
Ok some here may have read the threads Ive posted on my strange bad running problem. Ive piecemealed them together and tried many different things, but still no luck. I need to get this jeep running before hunting season. 98 XJ 4.0 Auto around 170K miles. Rusty's airtube and Flowmaster Catback if it matters. All installed almost 2 years now.
The beginning- Last fall, whenever I restarted my xj while it was still hot and put it into reverse, I would get a CEL, and the temp guage would max out, then drop back to normal. The CEL was Engine Coolant Temperature Circuit Low Voltage.
Tried cleaning the CTS, no luck. Finally went to the dealer and replaced it. Did not fix the problem. Then I read on here about how prone the Alt. is to failure after water crossings. Of course I had just been over the tires in water a couple weeks ago. Replaced Alt. with a new grand cherokee 136A, problem went away. Replaced belt at that time as well. Also did a fall tune up, new plugs, wires, cap and rotor button. All was well.
The middle- A little over a month after the beginning occured, I started having problems with poor idling. It got progressively worse over spring/summer until I am now here at Fall again, if anything further behind than I was before.
What happens-
1. Start XJ. Engine Temp does not matter. Problem happens when engine is warm or when engine is cold.
2. Runs fine for a couple minutes, almost always until it goes into closed loop mode.
3. Engine starts skipping, bogging, revving, shaking, making a racket in general. Can hear IAC trying to let in a lot of air. This happens no matter what I am doing, Idling, driving down the road at 40, it's not picky. HOWEVER if I hold it to WOT, problem goes away until I let off gas.
4. Problem just stops, usually with a little bit of a rev up, and jeep runs perfectly until I shut it off and let it sit off for more than 10-20 mins. Never actually timed it.
What I have tried-
New CTS, New TPS, New MAP, New Plugs, New rear O2 sensor. Cleaned IAC housing. Tried running it with IAC unplugged. Tried running with Upstream O2 sensor unplugged. Various types of fuel/system cleaners. Cleaned all the grounds I could find. Almost seemed to help, but may be wishful thinking. Tried unplugging Injectors, all appear to be working. Tested battery and Alt., machines all say OK.
Things suggested but didn't try-
Fuel pressure at the rail, but I would think i would be having problems across the board if there was a pump/line/pickup problem. Also havn't tried crank sensor, didn't think that could be involved but was recently suggested, could that cause this?
The worse news-
Today after wrenching on it trying to find anything wrong I go to put it in reverse with a warm engine....and the CEL came on with the same code that I thought I had fixed with the new Alt. Bloody Hell.
I've given up, my family's given up, and even my mechanic has given up. My options left are dealership, which I really really really don't want to do. Lack of trust. Or help from all the great people on here. I know it's rare to come on here and have an XJ problem that no one can help with, and I really hope that my jeep isn't beyond help and destined to be scrapped.
Any and all help will be greatly be appreciated, thanks and sorry for such a long post. And if theres anyone semi local that can help I am more than willing to pay in pizza/beer or whatever vice the help may indulge in.
What happens-
What I have tried-
The worse news-
