heyjpark1
- Oakesdale, WA
The other oil thread is up to 22 pages, and I got sick of reading everyone's anecdotal evidence of what the "best" oil is. This morning, I took 3 hours and wrote every major engine oil manufacturer with the following:
Hello,
Recently, we at the (North American XJ Association) have been debating the pros and cons of the various oils. To date, this "debate" is up to several hundred opionions on the pros and cons of various oils.
Rather then anecdotal evidence, I thought I would ask you about your product for use in our engines. Our engines (or most of them...) are the 4.0L inline 6 cylinder (found in Jeep Cherokees, Wranglers and Grand Cherokees). They have flat tappets, and so we know an oil with a higher level of ZDDP is desirable.
What is the ZDDP content of you various products? Do you have a recommendation on which product to use for our engines?
Thank you for your time, hundreds of us anticipate your response.
Sincerely,
Chris Clemens
In this thread, I'll post the responses as I get them. The only one I have so far is from Shell. Please don't turn this thread into an "I use this oil..." thread. If you want to talk about that, go to the 22 page thread. I would just like to use this thread to post the manufacturers responses and your comments.
Here goes the Shell response:
Chris, Rotella T with Triple Protection 15W-40 CJ-4 has approximately 1200 ppm (parts per million) zinc anti-wear. This is 50% more zinc than current passenger car motor oils (API SM/ILSAC GF-4) which contain approximately 800 ppm zinc. Passenger car motor oils had approximately 1200 ppm zinc prior to 2001. In 2001 the zinc was reduced to 1000 ppm and in 2005 reduced again to the current 800 ppm.
Thus, the new Rotella T with Triple Protection 15W-40 CJ-4 has the same zinc content that passenger car motor oils had in 2000 before the current problems with flat tappet engines began.
Thank you for your interest in Shell products.
P.S.- I know other people wrote to the manufacturers in the other thread, I just wanted a thread that consolidated their responses.
Hello,
Sincerely,
Chris Clemens
