HELP!WIRING DIAGRAM TO MIRROR
XJ88NO
Norway
Hey,I have trobble with electric mirror no my 88xj 4,0 Limited.
Hope some can help me with wiring diagram to it.
How I can connect a 12v to the switch.There is no power to it.No fuse deffect.
Please,if you have wiring diagram,send it to me!:helpme:
I will be very happy!:laugh3:
Per Garvag
Norway
[email protected]
DEAD THREAD, I COMMAND THEE TO RISE! (it's useful info)
The wiring for the power mirror switch on a 95/96 (and probably 94) is much the same but different color codes. Use the same diagram for these model years, but swap colors:
RED/WHT becomes PK (+12V)
BLK stays the same (GND)
BLU becomes DB/LB (all motor common)
YEL becomes YL/BK (left mirror up/down)
YEL/GRN becomes YL/LG (right mirror up/down)
WHT becomes DB (left mirror left/right)
WT/BK stays the same (right mirror left/right)
The common sides of the motors on the diagram given above by 8Mud are also partially swapped it seems - common on the 88 is down/right, common on 95/96 is up/right. Therefore you may have to swap the wires going to the up/down motor to get your switch buttons to make sense when wiring in 97+ power mirrors using the color codes given in this thread: http://naxja.org/forum/showthread.php?t=13330
I'm working on this, haven't done it yet but I have accumulated all the parts.
