87xjco
- Denver, CO
Well I don't know how well this is gonna work, but i'm trying a home built upper arm with my HP44 install. I hope to get more articulation and be able to eliminate the track bar. But I hear this only works with full hydro steering, so I may end up going back to 4 link and track bar.
I started with some 1.5" tube and made a few bends
I didn't plan on using this joint, with bolt facing forward like this, but theres just not enough room to turn it sideways, this joint uses a 3/4" bolt, it's BIG.
I have the axle stuffed all the way up to the stop on the left side so I can check for clearance, looks good
I made a mirror image of that tube and then spent alot of time getting the tubes to fit good
The tubes are tacked in place, i'll pull everything out as a unit and hope it doesn't move when I weld it.
