Old June 3rd, 2003, 20:16
RCP Phx RCP Phx is offline
Long arm pic!
Heres a teaser,Ary said he'd host some pics so hopefully I can get them on!
Its 2" chromoly tube w/ 1-1/4" chromoly allthread and 3/16" chromoly plate
Old June 3rd, 2003, 20:49
Economos Economos is offline
Sweet, my address is 202 Green Meadows Dr.
Old June 3rd, 2003, 21:33
ZPD's Avatar
ZPD ZPD is offline
That's what I talking about! Looking nice
Old June 3rd, 2003, 22:42
I'll try this.....
Old June 3rd, 2003, 23:39
Ted Z's Avatar
Ted Z Ted Z is offline
Thats exactly what i want to build......
How long are those...
Old June 3rd, 2003, 23:57
whitfimb's Avatar
whitfimb whitfimb is offline
Hmmm, Ho-made? Nice work. Now if I can just correctly plot the dimensions of the picture to scale, convert to CAD and hit the scan button.
Old June 4th, 2003, 06:01
They are 32" long and mounted high and inboard.If Ary'01XJ doesnt help w/ the pics I'll try to post a couple a day.
Old June 4th, 2003, 06:43
Ted Z's Avatar
webshots.com, free hosting and you can link pics....
Old June 4th, 2003, 08:56
5Cent's Avatar
5Cent 5Cent is offline
This is my buddies current setup. His arms and yours are almost identical. I love the way he ran them off his custom crossmember. Have a lookie....
http://community.webshots.com/user/hbtcob
Old June 4th, 2003, 10:26
MaXJohnson's Avatar
MaXJohnson MaXJohnson is offline
Workmanship looks good on your buddies LA's, but I'd be a little leary about the way the arm is bolted to the cross member. If you notice on the factory lower arm mount, two bolts at the rear wasn't good enough so the thru-bolt does most of the work. This is even considering that the factory arms have the help of upper arms to share the load.
Your buddies design has a single point of failure at the attachment point so it should be mucho beefy.
Heavier material + better attachment method = peace of mind.
Old June 4th, 2003, 15:39
let give this a try
I give up!!
Old June 4th, 2003, 16:16
MaXJohnson's Avatar
Originally posted by Ted Z
blah, blah, blah...
Hey Ted, your avatar is way cool.
I like it!
Old June 4th, 2003, 16:59
cherokeekid's Avatar
cherokeekid cherokeekid is offline
Re: Long arm pic!
Did you purchase the threaded female tube at the Johnny joint end? If so where did you get it?
Old June 4th, 2003, 18:58
No its a rod coupling that was turned down on a lathe.I e-mailed my pics to Ary so hopefully the pics will get up and everything will be answered!
Long Arm Kits BobCSmith Modified Tech Discussion 18 September 23rd, 2004 15:27
Radius arm setup w/ a twist? csudman Modified Tech Discussion 19 December 8th, 2003 10:27
Control Arm Question aueaglexj Modified Tech Discussion 1 December 6th, 2003 19:35
Beezil and other long arm mounters :) Jeff 98XJ WI Modified Tech Discussion 22 May 13th, 2003 07:48
PIC Test KINGSIZE TEST Forum 2 April 7th, 2003 01:48
