bonesxj89
- running springs
I need to replace my stock steering. I was thinking of using JRC stuff. Good or Bad, whats your thoughts.
I'm going with the Currie setup. Not familiar with JCR's but my dad has been running Currie for years and nothing has come close to bending or breaking.
http://www.4wheelparts.com/Brakes-S...aspx?t_c=65&t_s=430&t_pt=6195&t_pn=CURCE-9701
tie rod roll being the big one...
and depending on the orientation (UTK vs OTK) you may need to relocate the sway bar links and/or track bar.
I have bent the tie rod twice on my Currie setup. Other than that its pure beef and great for 6" lift and under. The tie rod is made to bend first and can be straightened out fairly easily. Worth the money IMHO
I would pass on the currie setup. Pop a tre on the trail and where do you get a new one. You have to buy currie ends and they are pricey. Too pricey to carry spares for most people. Atleast with a one ton setup it's way cheaper to carry spares and if not you can get them at any auto parts store.
I thought the same thing. But I can't seem to break one, only wear out the tre's. Actually, the tre's are fine but the boots need replacing on 3 of the ends. I carry currie spares, and yeah they are pricey but I have never broke and have never seen one break. And the currie stuff has better road manners by far, no noticeable tie rod roll like the 1 ton setups.
its a band aid at best.A uhmw spacer will take care of that roll for the life of the steering.
it uses the same taper as stock TREs. you can throw on a stock tie rod or drag link to get you home.I would pass on the currie setup. Pop a tre on the trail and where do you get a new one. You have to buy currie ends and they are pricey. Too pricey to carry spares for most people. Atleast with a one ton setup it's way cheaper to carry spares and if not you can get them at any auto parts store.
this...I thought the same thing. But I can't seem to break one, only wear out the tre's. Actually, the tre's are fine but the boots need replacing on 3 of the ends. I carry currie spares, and yeah they are pricey but I have never broke and have never seen one break. And the currie stuff has better road manners by far, no noticeable tie rod roll like the 1 ton setups.
for the life of the steering?... they wear out regularly.I myself broke a currie end on my last jeep. Ended up having to throw stock steering back on to get off it the trail and home. And like I said a uhmw spacer under the passenger tre on a one ton setup will keep the roll away for the life of the steering.
I'm speaking from experience for what worked on my rigs. Take it or leave it. Not hurting my feelings.
