frontman
- Cameronpark Ca
I have a 91 4.0 with an RE 3.5 lift. Alittle while back and all of a sudden I started to get a small vibration coming from the front end. I was told it was probly a bad front shaft since I have a locker up front and it started suddenly and after having the locker in for awhile. So I pulled the shaft and have been driving it for some time (with no vibration) until I had the time and extra money for a shaft. Anyways I came across a lightly used shaft from which the PO said only had about 2k miles on it and installed it this weekend before my snow run. Well the vibration is still there. I starts at about 45 mph, gets really bad between 55-65, and seems to settle out some around 70 mph. I have checked and tightened everything I could transfer case UCA's, LCA's, track bar etc. but cannot locate source. Anyone have any other ideas. Im stuck and really dont want to take this to a shop to figure out. Thanx in advance.
