AKswampheep
- INDIANER
OK, heres the thing, i was messing around awhile back in 4 low and i somehow busted the back driveshaft u joint, so i put a new u joint in it and it comes to be that the little side pin on the yoke broke off, so i replaced the yoke, put a new u joint in, put the driveshaft in and i went for a drive, when taking off from a dead stop it it vibrates, feels like slow axle hop except thats not what it is, also, while the back driveshaft was out, i absolutely had to drive, since school and all, so i drove it in 4wd and yes i know t-case fluid leaks out without the driveshaft in but i only drove it for 3-4 days, on the 4th day i went to take off hard and it sounded like i snapped the t-case chain? can anyone help me with the d-shaft problem and tell the possibility of the chain breaking? BTW rear wheel drive still works
