Old February 26th, 2018, 18:47
zluster's Avatar
zluster zluster is offline
Re: Project CRD MJ is born:
Tested the TJ gauge cluster finally!
https://www.youtube.com/watch?v=xpO4isRTThs
However I thought the KJ plugs were the style I needed but it turned out they have more pins than the TJ, so I need to find the same connector type but with fewer pins to fit the TJ cluster.
Grrr, back to the junkyards to raid 15 year old Chryslers.
Old February 27th, 2018, 13:09
zluster's Avatar
I will need to do some more testing in the future where I read through the OBDII port with a scanner to show what PSI to oil pressure sensor is seeing, and how that translates to the position on the TJ guage cluster. The TJ cluster is reading oil pressure through the PCI bus from the ECU, and then displaying that as an analog value. The question comes up as the the calibration, when it read "half" what PSI was that? When it went higher to 3/4 what PSI was that?
If you noticed the oil pressure gauge is the only one that does not have any units shown. This is because on the 2002+ TJ the oil pressure gauge is basically just an idiot light! The sensor on the newer TJ is a discrete, meaning it is either open or closed. In theory, when off or no pressure the switch is open circuit, and then when the engine is on and oil pressure is "good" it is closed. This way if your oil pressure drops below "good" or if it fails it should go open circuit. What the TJ ECU does is read this open or closed switch and send a value to the cluster. So the TJ cluster reading from the ECU only sees 0 PSI/bad, or X PSI/good. This means that on a stock TJ the oil pressure gauge either shows zero, or middle. Since the gauge is then basically just an idiot light they removed the units of measure.
However since the CRD ECU does read an analog pressure from the oil pressure sender the REAL psi is transmitted over the PCI bus, and since the TJ cluster is reading a real analog value it drives the gauge accordingly. The only thing left for me is to determine exactly what pressure the middle means, and exactly what pressure the high means.
I am working on a way to read the calibration from the processor onboard, which may allow me to change the scaling factor on the gauge. Likely that will be much further along, I'm just happy the Main functions, fuel level, coolant temp, RPM, and presumably speed all read correct.
In final form this will be wired into the normal dash wiring for the cluster for all functions such as turn signals, lights, 4wd indicator, etc, leaving the obdii port completely open like factory.
Old February 28th, 2018, 16:46
zluster's Avatar
My coworker came over last sunday to use my pressure washer on his newly acquired wildernest to get it cleaned up, I decided it was a good time to open mine and take a look inside the back of the MJ........I'm find all sorts of parts I forgot where back there.
Fun times ahead! Looking forward to having both MJs out and be camping!
Old February 28th, 2018, 16:48
zluster's Avatar
zluster's Avatar
I made some progress on the TJ gauge cluster, I cannot seem to program less than 1000 miles, I suppose thats close enough to zero? I was just really looking forward to seeing it run up from zero. I might keep playing with it, I also want to figure out to reprogram the VIN.
Old March 2nd, 2018, 21:55
zluster's Avatar
Wiring work continues on the main engine harness:
Auto trans stuff removed:
I gotta start sitting down the with the Xj wiring diagrams and the KJ wiring diagrams to see what I can adapt from one to the other, and what I need to add, like glow plug relays. etc.
Old August 2nd, 2019, 06:39
CSpeade51 CSpeade51 is offline
would like to see more of this. or find out what ultimately happened here.
Old August 4th, 2019, 18:36
freerider15 freerider15 is offline
Well, he got a Dirtbound rear DIY bumper which we put together and I got all welded up.
Since then...not a whole lot
Old August 15th, 2019, 01:07
tm8chris tm8chris is offline
Nice rig. Any more updates?
Old March 28th, 2020, 18:10
Mason_T Mason_T is offline
Originally Posted by zluster View Post
Bought this NV3550 for my MJ today for $550:
As you can see the bellhousing is broken so I got him down by $50, its the wrong bellhousing for me anyways, pictured next to it is the correct bellhousing for the CRD engine.
What bellhousing is the correct one? I assume its the bellhousing from the 2.5 that the europeans got, but I was hoping there would be a better option for sourcing one in the states. I also was curious what you're doing for a clutch if it is a 2.5 bellhousing would you use the 2.5 clutch and flywheel and hope the flywheel bolt pattern didn't change when they changed the stroke to get the extra displacement or would you go for the 2.8 and be pretty sure that the starter meshes properly? On that note do you know if the starter from the auto compatible with the NV3550?
Project 100$XJ and Project JEEPSPEED AZXJ Arizona Chapter 23 August 23rd, 2007 12:57
91 4dr project 33s, 91 4 dr project stock Rockhound For Sale: Private Party Only. XJ ITEMS ONLY 1 May 8th, 2007 20:13
Big Project needs big help.... Clint Intermountain Chapter 63 March 20th, 2007 04:40
Future Jeeper is born Jess South East Chapter 10 December 1st, 2006 18:33
A 4x4 is Born.... Purple Non-Tech / Off Topic 7 January 9th, 2006 22:59
