Wow..the Spobi is flowing today.....
Sample....YOU TOOK MY TRANNY!!!!
I was trying to cut a deal with Rix to get it..
No biggie...It gives me a chance to rebuild mine.
1. the 228 AND 229 cases were offered in XJ's...BOTH are fulltime cases.
2. The transmission is an A904..Almost the same as a 727TF
3. That transmission is like finding GOLD..Seeing as it was cast by ZF in Germany, and built in detroit.
4. the axles are NOT the strongest..Seeing as the rear axle is a 2 piece unit, with no c-clips. the axle flange is pressed onto the axle.
5. One redeeming value is the FIXED REAR YOKE on the tcase.
6. the 2.8 used in the AMC XJ's WILL turn a set of 36's..Just not well STOCK....Drop in a FI setup, or even a 3.4 and go to town.
7. Having axles laying around means he's thinking about a swap..The stock 35, and 30 WILL NOT HOLD 36's AT ALL..ESPECALLY with the AMC axles.
8. t-case drops are NOT needed for around 5 inches on the AMC FIXED yoke XJ's..I'm at 4" and NO, REPEAT NO Vibes. Sure I needed a longer D-shaft, but that's IT.
9. A better option might be to scrap the entire AMC drivetrain, and drop in a SBC, and tranny/case combo out of a Blazer....Seeing as they had PAss. Drop cases. It's not as hard as you think.
10. Do what YOU want...Not what a BB says is "Best for you"
PM me over there--------> andI'll pass on some sage advice.
