Andy in Pa.
NAXJA Member #180
- Downingtown, Pa.
I found a local one-man operation in West Chester and went down to talk to him last night about my S&W roll cage. This guy used to work for S&W, and understood how they fit their cages. He is going to install my cage next week, with a few additions. I'm not doing the shelf in the back yet to mount the spare to, but once the cage is in, I'll be able to better visualize how I want to install the shelf. All told, the cage is going to attach to the Jeep at 12 points, 2 in the front coming down from the halo at the drivers and passengers feet, 2 tying in the front seat belt mounts, 2 at the main hoop to the floor, 2 going from the joint at the main hoop and the stringer running across the middle of the main hoop running to the tranny tunnel, 2 tying in the rear seat belt mounts, and 2 at the rear hatch. He is putting it in nice and tight too. It won't be in the way of getting in and out for the driver and passenger. If your looking at the side of the Jeep, you won't be able to tell it has a cage inside. He is doing some additions like OH SHIT handles for driver and passenger, center tube running down the middle of the halo, and some trussing in a few of the critical corners.
Should be nice and stiff when its done. THEN we have to get out and do some wheeling so I can see if it limited my flex.
Also, one thing I found interesting is when I removed my Rusty's two-point bar it seemed to loosen the Jeep up on the road a little bit. I still say that if anyone is looking for a cheap solution for now, that Rusty's bar does stiffen up an XJ noticeably. Its less than $200.00 and takes about 1/2 hour to bolt it in. The doors open and close much better when flexed up too.
Andy
Andy
