Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > Sierra Chapter
Sierra Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Thread Tools Rating: Thread Rating: 11 votes, 3.55 average. Display Modes
  #766
Old April 11th, 2018, 12:02
Skipper51's Avatar
Skipper51 Skipper51 is offline
Re: Yet another... Build thread for an xj on 40s and one tons in norcal
That’s great Jon . Will you be bringing the red rig to the meet and greet tomorrow? I would love to see it.
2000 XJ, on 33's;
My we strive to leave every place we visit at least a little better than when we arrived.
Old April 11th, 2018, 13:21
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Yep I plan to bring it tomorrow .
It still seems to have a little something going on with it, not 100% sure. I was driving on a hill and it started to lag a bit. Could have been that the trans shifted too early though
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old April 11th, 2018, 16:01
Changing plugs out to NGK BKR7E according to my tuner these are the plugs to run. It also looks like in my data log from todays drive that my TPS has a dead spot possibly or a bad connection, reads randomly .5% open, when idle alone is 16.5%, so something is not right there. So I ordered a new TPS and pigtail.
Old April 16th, 2018, 22:07
We are narrowing things down
(thanks for the tail pipe reading Cristoph aka clydefrog) and also thanks to the input and analysis from Spencer
Dizzy is indexed good amount over stock but not too far I dont think.
New Mopar : CPS, TPS, MAP, IAT, and Coolant sensor.
New NGK: Coil, o2, plugs
New wideband is on order(again, third wideband, whole new brand this time) , and we are suspecting possible bad wideband and/or bad ECU at this point since the wideband is reading on the leaner side and the tail pipe and motor oil are reading crazy rich. Or possible bad wiring somewhere.
Coolant temps in my data logs seem to be reading low (like reading 70* when the temp gauge is 170* and the rig is obviously warmed up) which is weird and could be part of the problem I suppose.
Old April 17th, 2018, 11:28
Old April 17th, 2018, 11:29
talking with spencer, it looks like the tail pipe reading is on point with the wideband now, it looks like a 13% co2% is on par with 14.7 A/F ratio. SO it seems like its ok so far.
Old April 17th, 2018, 22:22
twinhauler's Avatar
twinhauler twinhauler is offline
Reading 70 degrees and not 170 degrees could and maybe be a big issue...
Old April 17th, 2018, 22:51
Yeah . I need to make sure thats maybe like celsius or maybe just the livefeed being off
Old May 23rd, 2018, 23:54
Well ive been wrenching non stop since friday. Blew out rear hub seals. Lost brakes . Replaced rear calipers and master and fronts are new. No air i can find. New leaves on driver side. Removed traction bar. Been bleeding brakes non stip since saturday. New banjo bolts. Doesnt stop. Pedal doesnt even feel remotely good. Ive done so many braking systems in my life and never had a persistent no brakes situation after bleeding the master so many times and maybe 8 hrs of bleeding all 4 corners . Might be faster to fix my wagoneer .
Old May 23rd, 2018, 23:56
Before new driver side leaves and removing the traction bar i had no down travel at all and traction bar was fully bound up allowin no droop and driver sides leaves where bent after 400 miles and had sagged 2.5-3. Just my luck
Old Yesterday, 23:16
jabbathewhats's Avatar
jabbathewhats jabbathewhats is offline
Wtf. Crazy. Did your axle shift or something? What caused it to get so bound up?
Old Yesterday, 23:36
Dropped lift and moved axle forward
Rate This Thread:
Just Another XJ on tons, coilovers, 42's, etc. Build freerider15 Advanced Fabrication and Engineering 555 May 2nd, 2017 10:36
Another xj build thread scsmxj Modified Tech Discussion 4 April 6th, 2012 18:41
my 91 xj build thread Vanimal Modified Tech Discussion 68 March 25th, 2012 18:22
Looking to build tons...... Nick_n_ii Modified Tech Discussion 14 March 24th, 2011 07:16
Updated Tons of Parts Thread... swbooking SoCal For Sale 32 August 19th, 2008 13:08
