Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Events > Past NAXJA Events > PAST NAXJA EVENTS > ColoradoFest 2011
ColoradoFest 2011 July 25-30, 2011 in Ouray, Colorado
Old February 9th, 2011, 19:02
old_man's Avatar
old_man old_man is offline
MANDITORY SAFETY CHECKS
All vehicles will be inspected prior to participating in any runs. If you want to ride with us, you have to at least meet these standards. You have lots of time to get this in order, so no excuses will be accepted.
1. At least one, visibly charged fire extinguisher (Type B:C, or A:B:C)
2. First Aid Kit
3. Adequate spare tire, Jack, and Lug Wrench
4. Safety belts for driver and any pasengers
5. Adequate attachment points in the front AND rear of the vehicle. Acceptable forms of attachment points are: Tow Hooks of OEM or greater integrity, D-Rings, Shackles or Clevis.
6. At least one, 20ft, 10,000 lb Snatch Strap WITHOUT metal hooks.
7. A properly secured Battery
8. All heavy objects inside the vehicle must be securely stowed and tied down.
Missing some of these? Then, get your butt in gear and get some! You have several months!
In addition, we have some SUGGESTIONS for further enhancing the safety and comfort of your ride:
A functioning CB radio - permanent or handheld (This one should actually be a minimum requirement, and it is highly recommended!)
Appropriate Tools
A 2nd Fire Extinguisher
Duct Tape
Rocker Protection or Armor
Skid Plates (at least Transfer Case and Gas Tank)
Tires in Good Condition (especially sidewalls) Note: AT's are usually better than MT's for this terrain.
One Gallon of Water per person
Hi-energy snacks
Critical vehicle fluids (engine oil, ATF, Coolant, Gear Oil) Gasoline only in approved, well mounted EXTERIOR containers. Better choice: make sure you are FULL before you start the trail (Ask me how I know)
Hi-Lift Jack
Spare Parts (especially hoses and belts. Machined parts if you REALLY are concerned)
Tarp, spare rope
Emergency Signaling devices
Detailed Topo Maps / GPS
Change of clothing/shoes, warmer outerwear, blanket.
Tom Houston - Former Colorado Chapter Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
  #2
Old February 13th, 2011, 17:28
eflores eflores is offline
Re: MANDITORY SAFETY CHECKS
Won't Janine have most of th fluids and parts though???
  #3
Old February 13th, 2011, 18:21
old_man's Avatar
She probably will, but you can't keep up with her so you are out of luck.
  #4
Old February 15th, 2011, 14:27
bmpweXJ bmpweXJ is offline
related question, what size fire estinguisher do you guys run with?
  #5
Old February 16th, 2011, 05:56
Phil's Avatar
Phil Phil is offline
For buggy or buggy-like vehicles, may a strap be wrapped or passed around fully welded tube bumpers or crossmembers in lieu of tow hooks or D-ring mounts?
Spotters lead the way!
My green junk.
1989 XJ Wagoneer. Basically stock.
G & G Offroad and Auto Repair can make you think you can run the Box!
  #6
Old February 16th, 2011, 19:00
OddBallXJ's Avatar
OddBallXJ OddBallXJ is offline
I carry 2- 10B:C auto/marine fire ext in the jeep. Picked them up at Lowes for less than $20 ea.
  #7
Old February 17th, 2011, 06:59
old_man's Avatar
Common sense will prevail. If it is strong enough and safe enough, then all will be fine.
  #8
Old March 29th, 2011, 14:43
DutchVDub's Avatar
DutchVDub DutchVDub is offline
On a trailered rig/buggy is a spare required to be on the vehicle? I have no idea where i would mount a 39.5" spare on my Jeep. Even if I were to get a flat it would still be able to limp back to the trailer or worse case run back down and snatch it up.
Americans can sleep at night because US Soldiers stand ready to fight
  #9
Old April 3rd, 2011, 18:39
Led's Avatar
Led Led is offline
For the hard core group we tend to know what we need and where to keep it and tend to be in a smaller group on shorter trails
acting like 12 year old girls since 1999
Truggy 2.0 coming soon to a web near you
  #10
Old April 4th, 2011, 19:10
DutchVDub's Avatar
So if I don't have a spare on the rig thats cool? I don't even have one yet and as I'm planing on going to a different rim/tire next year I'd prefer not to even bother. I can borrow one for this trip if absolutely neccessary ( a buddy runs the same tires) but I definately don't want to have to fab up a tire mount for 1 trip.
  #11
Old April 13th, 2011, 20:56
DutchVDub's Avatar
I'll take the lack of an answer as meaning I don't a spare on my almost buggy, thanks for playing.
  #12
Old April 14th, 2011, 08:26
.40CalPatriot's Avatar
.40CalPatriot .40CalPatriot is offline
Dutch, I think you will be fine as long as you have one availible. I think we can make exeptions, one on your trailer works for me.
Rate This Thread:
No Spark at Coil..ICM checks good Johnny C. OEM Tech Discussion 2 July 16th, 2006 18:48
Need help with safety checks..... Danno Moab Fall Fling October 2004 8 September 9th, 2004 07:28
Checks CRASH XJ Fest 2004: Rubicon 1 August 11th, 2004 15:42
