yes, you can do the swap, but it takes some creativity. I am almost done with converting mine. I wanted to retain my interior and upgrade to one piece windows. I first thought about making the window tracks work with the old door, but there is too much headache getting the regulator to work. I was able to find a pair of used 97+ manual doors..
The only fab you have to do is:
Holes for door panel clips, arm rest mounts, interior handle/lockrods and modify the door striker on the body.
The old door cranks will not attach to the new regulator, i'm using the new style for now.
The good news is that the hole for the window crank is in the right spot
I will post up some pictures when I get a chance.
