99xj4x4
- Bakersfield/ Chico
Ok so this weekend I broke an 8.25 axle driver side shaft. It broke right at the taper well out side of the locker. It is the cleanest brake Ive ever seen, so there were no fragments. So on the trail I threw in the long side shaft on the drivers side. When I hit the gas only the passenger side was locked. The Detroit was making a noise I have never heard a Detroit make, like a ratcheting, something’s broken sound.
I drove it 200 miles home, and somewhere during the trip home it started to lock again, but now its not disengaging. The driver side tire drags around every corner. The diff fluid was really thin when I cracked the cover, so it must be getting really hot. I didn’t see any metal filings or chunks in the fluid (it was dark though so ill look again in the am).
So tomorrow Im taking the locker apart to see if I can spot anything obvious... What should I look for, what are the common problems? Ive never opened up a Detroit before and have a general knowledge of how it actually works internally at best. Any help will be greatly appreciated.
