carguy007
- Central TX
2001 XJ, 4.0L auto. This is my son’s XJ, daily driver to/from school
3 weeks ago replaced 2 top O2 sensors, NTK Brand . (hindsight should've done all 4 at once), not sure if this relevant.
A week later CEL comes on - P1694, my son said gauges would go to zero and engine would briefly cut off for a second, but would keep running. It would do this every couple of minutes. Towed it home
Checked & cleaned all grounds, bought a new battery (old one tested bad), cleaned terminals on back of cluster. cleared code and all was good for another week.
Week later - same issue – this time would not fire and had “no bus” on odometer. It sat overnight, and fired the next morning, but same symptoms. When I fired it that morning, I checked and picked up 2 additional codes: P0130 & P0136. I went ahead and replaced the lower O2 sensors (NTK).
The crank sensor and cam sensors were replaced 6 months ago. Rechecked crank sensor with ohm meter – good.
Here is the issue:
Checked voltage on DLC - reading .32 volts on pin 3, and .09 volts on pins 11, ground to pins 4/5. This voltage did not change by removing Crank, Cam, TPS and Map sensors. The pin 3 reading went to .13 volts when I disconnected TCM.
Checked resistance on DLC pin 3 and pin 11 = 60 ohms (should be 120)
Checked resistance on harness both CCD+ and CCD- between PCM and TCM – 0 ohms good
Checked voltage from PCM on both orange and purple wires, both 5v – good
This leads me to believe it’s the TCM. Is there a way to test the TCM? I believe it was shifting fine previously.
Is there anything else to check?
Lastly, if you can provide a link for a FSM download, that would be great. Most of those sites redirect everywhere.
Thanks in advance.
Here is the issue:
Thanks in advance.
