Three day Dec. ROTM tie braking runoff poll
choose a winner for the tie
  • ExTankerGuy
    Votes: 16 42.1%
  • BRIANHO13
    Votes: 22 57.9%
  • Total voters
    38
  • Poll closed .
REWSTER
BACON!
bourbonnais IL
:clap: hadn't made any plans for this sort of thing so im winging it...
We have a tie in the ROTM so lets do a head to head poll.
here were the contestants
1987 Jeep XJ Wagoneer
4.0 litre 6 cylinder
AW4 Transmission
NP242 Transfer Case with Novak transfer case shifter and Tom Woods SYE and drive shaft
37" Pit Bull Rockers
15x10 Aluminum TrailReady Beadlocks
4.5" lift
Chevy pickup front brake lines
Late model brake booster/master cylinder
Rusty's adjustable upper and lower control arms
PSC performance power steering pump
Durango steering box
Brown Dog Offroad Poly motor mounts
TNT Customs track bar
ARB air compressor w/tire inflator kit
D44 front axle w/5.38 gears, Detroit locker, alloy shafts, Nitro Excalibur u-joints, Chevy flat top knuckles, crossover steering
(all brackets have been moved up so nothing hangs below axle tube)
D44 rear axle w/5.38 gears, Detroit locker, alloy shafts, custom high clearance shock mounts
Rockcrusher rear diff cover
Riddler front diff cover
AJ's Off-Road Armor front and rear bumpers
AJ's Off-Road Armor rock rails
TNT Customs HD skidplate/belly pan
TNT Customs unibody stiffeners
HD Off Road Engineering Shackle Relocators
"Joel Built" custom gas tank skid
LED rock lights
Warn X8000i winch w/Masterpull Synthetic Rope and 12 Volt Guy in cab control
Optima Red Top battery
K&N open element air filter
Flowmaster 50 series muffler
Tube doors
Hunsaker Icon Seats
Uniden CB w/weather radio
Numerous beauty marks
Trail Rated Badge
AND
I'll play, since I still own it.
98 xj 4.0 with ax15
231-300 doubler
dana 60 front spooled
yukon 35 spline inners and outters with drive slugs
yukon super joints
hi steer
full hydro
3 link front (lowers are 2" 1/4 wall chromoly)
14 bolt rear (welded)
4 link rear (lowers are 2" 1/4 wall chromoly)
42" irocs
steel beadlocks
cutting brakes
tom woods shafts front and rear
tom woods spare rear and a extended stock front spare
m8000 winch
front suckdown winch (behind front bumper)
s.s. custom fuel cell that uses stock pump
yellow top relocated to back
4 point harnesses
all cage tubing is 1.75" 120 wall DOM
lets get some more voting going on and pick a winner this time!
if you guys feel like posting more photos or videos to boost your votes. Id be ok with that :D
So did you get the squirrel?
get your votes in. poll closes in a couple hours!
can Mr Tanker make a comeback?
will Mr Ho keep the lead?
you decide...
