High pinion dana 60 rear axle, high pinion dana 44 front, ARBs, 5.38s, chromos
blondejoncherokee
sacramento
(yes thats a high pinion rear !)
High pinion front dana 44
high steer
5.38s
ARBS
rear has dutchman chromos and some 500$ disc brakes
front is ford, cant tell if they are chromos or stock shafts
5 on 5.5
1350 yokes
Both are set up for a YJ with a spring over.
4500$ for the pair.
located in Colfax.
also have some 37/12.5/15s on 15" rims, 5 on 5.5 steelies
great tread, maybe 85-95% tread. rears are Irocs, front at the Truxxus Mts, newer
1200$ for the 4 tires mounted on rims.
price drop to 4000$
will throw in a ARB compressor, wiring harness, and solenoids and switches too.
will wheel and deal with tires IF you buy the axles too
I really shouldn't be considering them right now, but I am intrigued if both axles will fit on a single standard size 60" x 48" pallet diagonally.
An approximate wms to wms measurement would be useful for each axle.
What is the year of manufacture for each tire?
How heavy are the axles? I'm guessing each may be around 500lbs.
Pallet is 72lbs, so looking at around 1,100lbs shipping weight for the axles.
The maximum pallet load is 3,500lbs so if a timber frame could be made over the axles for the tires they could go on the same shipment.
Tire weight 75lbs each = 300lbs total
Steel wheel weight 25lbs = 100lbs total
Estimating 1,600lbs shipping weight combined.
Got any photos of the axles and tires?
Front has chromos too.
Dropping rear down to 2K and tires on rims down to 750$ just to move things along if anyone on here needs a deal.
44 sold.
