Rig readyness for Harlan
PacificEd
Middle Tennessee
So what all needs to be done to get your rigs ready to wheel?
My list:
install Aussie locker
fuel tank skid
replace front floor
upgrade D30 maybe with some better shafts
install roof rack
replace heater core
I'm sure that isn't all.
Oh gosh.....
Install...
1. Aussie Locker
2. Rear Ruff Stuff Cover
3. JKS Quicker Disco's
4. JKS 1" Boomerang Shackles
5. JKS ACOS
6. JCR Stage 4 Front Bumper
7. Iron Rock Off Road Track Bar
8. Iron Rock Off Road BPE's
9. CB Radio and antenna
10. Tomken Gas Tank Skid (if it ever ships)
Obtain and Install
1. Transfer Case Skid
2. Possibly some sliders
my junk needs
new hubs
reweld rear shockmount
rear bumper with a towpoint
stroker motor finished
stroker motor installed in rig
keep happy right foot from buning up trans doing donuts with stroker installed in rig
of course i could wheel it right now the way it sits, just isnt "finished" yet
Well:
TNT Long arms
Longer brake lines
Longer shocks
Taller coils
Extended shackles
Traction bar
1/4 Guards
35's & beadlocks
BPE's
New track bar & Bracket
CB install
Radio Install & New speakers (long drive to Harlan on 35's & beadlocks)
Track bar brace
Mini Skids on D30
That should be most of it. :cheers:
go through the suspension.
build new front bumper
paint and install new front clip
replace exhaust manifold
make sure the tow rig is ready for the long haul!
Install skids and bumpers and Figure out how I'm gonna Afford gas for the trip!
Traction bar.
Finish Hoe Bracket install!
What ever I feel like doing..... really need to tie the cage into the unibody better.
find PS leak. :tears:
install new tie rod, including weld on tabs to said tie rod.
Sell wife to some blind, deaf, and dumb rich guy for funds..... :eyes:
Well:
TNT Long arms
Longer brake lines
Longer shocks
Taller coils
Extended shackles
Traction bar
1/4 Guards
35's & beadlocks
BPE's
CB install
Track bar brace
Mini Skids on D30
I must have missed it...what happened to your other rig?
Need:
Rear traction bar
Check fluids
Swap shackles
Bumpstops/limit straps
Swaybar axle mount modification
New exhaust
Belly skid
Put on trailer
Want:
Some more cage pieces
Cargo tiedowns
Oil pressure/temp gauge troubleshooting
Suspension Seat install with harnesses
Better rear car seat mounting
Rear DVD install :D
i have a to do list for three jeeps.... dang this is gettin to be too much ;)
The trail rig didn't have A/C so I built another one.:D:roflmao:
No, that's not it, really.... I gave up my tow rig so I had no way to haul the trail rig. So.....the trail rig donated some parts to the weekend warrior and the new trail rig was born but this one is drivable to and from the trails. Outside of the cage, it should be just as capable if not more so than the other one plus it has A/C and a radio!!:)
My true trail rig is as Doug stated, for now. It actually has a 2WD axle in the front and a soon to be 35 in the rear.:cry:
so your building a teenage proof xj? caged for the young rollover driver in us all... 2wd to keep from pesky mudhole adventures... and a 35 to prevent hard unruly acceleration, as this may cause axle explosion and loss of driving priveleges.... i think you should let jackie drive it ;)
...... dont tell her i said that she'll prob get pissed at me next time i see her
Haha, and you guys thought you had it rough... I have to build my whole rig before then!!! Fortunately, it is coming along very nicely and I should have it done in time, as long as the ORIs are ready at the beginning of June. However, Brent is coming to the crawl too, and he is also getting Front and rear axle swaps and ORIs, so I have 2 vehicles to finish in less than a month. Luckily, I can pretty much finish the buggy without the struts... I'll just have to mount them and paint it to finish it, but Brents will require quite a bit more since he drives his... it can't be torn down just sitting on blocks waiting on the Struts. So much work, so little time to do it in.
I have to get my CB figured out cause its acting dumb. Got my motor built and broke it. Maybe new tires before then too. Might ditch the doors and chop/dove tail it if I'm feeling froggy
heads gettin tore apart and magnafluxed on mon..... i think its cracked.... we'll get there with stroker in jeep, just not as easily as i thought....
I didn't break anything today but pleanty of things to fix b4 Harlan......Good times.
