Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > WK and WK2 Grand Cherokees (2005 - Present)
WK and WK2 Grand Cherokees (2005 - Present) Technical forum focused on the new generation Grand Cherokees.
Old July 5th, 2017, 08:31
shelbyluvv's Avatar
shelbyluvv shelbyluvv is offline
WK2 air suspension
I want to lift my 2017 WK2 TH with air suspension. How can this be accomplished and not void my lifetime warranty?
Old July 6th, 2017, 04:25
Bryan C.'s Avatar
Bryan C. Bryan C. is offline
Re: WK2 air suspension
Push the suspension level button to the off road 2 setting. No need for a lift kit when you are a big baller driving a new WK.
Old July 6th, 2017, 08:02
shelbyluvv's Avatar
This is exactly the kind of response I knew I would get. And why I am so against this expansion to other platforms.
What will you guys say to the poor guy who wants to lift his FWD KL? I can already see the replies that it isn't a real Jeep and they are ugly. Blah, Blah, Blah.
Old July 6th, 2017, 13:06
Kittrell's Avatar
Kittrell Kittrell is offline
As far as I am informed there is no lift you can buy for the QL system. This is a little dated but has some good information.
http://www.jeepgarage.org/f109/lift-...s-91962-2.html
some more here
http://www.jeepforum.com/forum/f309/...tions-3847305/
Old July 6th, 2017, 13:17
shelbyluvv's Avatar
I will admit I know the answer to my question but I want to see what kind of information will be googled and spit out here. There is a way to lock out the suspension at any speed and to control it with a knob.
This was more to prove my point that this new expansion is not needed. The tech is out there for all these Jeeps.
Sent from my XT1254 using Tapatalk
Old July 6th, 2017, 19:45
Anak's Avatar
Anak Anak is offline
Stranger
Dang pop quizzes.
Old July 6th, 2017, 21:11
Bent's Avatar
Bent Bent is offline
Only Slightly Psychotic
Nominated.
Gravity is a fickle mistress.
Ethan: "What did you think would happen?"
'01 XJ 4.0 AW4 231 Modified
'87 MJ 4.0 AW4 231 Stock-ish
SoCal Chapter Past President
Old July 6th, 2017, 21:13
Anak's Avatar
Stranger
Originally Posted by shelbyluvv View Post
-Removed by moderator-
And you get this bent out of shape over a possible implication?
Who can't act like a man here?
Old July 6th, 2017, 21:15
Bent's Avatar
Doesn't appear to be able to hold his liquor either.
Old July 6th, 2017, 21:20
Anak's Avatar
Stranger
The lady doth protest too much, methinks.
Old July 6th, 2017, 22:22
GSequoia's Avatar
GSequoia GSequoia is offline
Everyone says I'm a jerk.
You know you're laying it on thick there Bo, knock it off.
You have to expect sarcastic responses to a sarcastic thread, it was easy to see what your goal was from the get go.
Prior President & Prior SoCal Chapter President
Originally Posted by Bent
Us normal people...
Old July 6th, 2017, 23:26
Bryan C.'s Avatar
Obvious troll is obvious.
Old July 7th, 2017, 03:55
MoparManiac's Avatar
MoparManiac MoparManiac is offline
^ This.
Old July 7th, 2017, 10:18
Green XJ Jeep Green XJ Jeep is offline
NAXJA Member 4950
Knowing nothing about Trailhawks other than in my opinion they are butt ugly,
I found the answer informative amd had no idea whatsoever they had air suspension.
Knowing that you are attempting to facetious and malicious i need to google the lifetime warranty part.
Old July 10th, 2017, 16:51
ashmanjeepxj's Avatar
ashmanjeepxj ashmanjeepxj is offline
Build your own adjustable links to lower or raise normal ride height.
http://www.jeepgarage.org/f109/diy-h...ics-94371.html
Off-road 2 is only allowed up to 25MPH, then it auto lowers to ride height but you can fool it with adjustable links so normal ride height is taller.
Our eco diesel grand Cherokee rides terrible on the tall off road 2 height. The shocks are almost fully extended and top out on every small bump.
I like the air suspension, It rides good and is great for my wife towing but lame off road and needs more rebound.
Air Suspension Lowrange2 South East Chapter 7 December 22nd, 2011 15:05
Air bag suspension old_man Adventure Forum 4 March 2nd, 2010 13:44
Suspension darkoverlift Modified Tech Discussion 4 October 9th, 2009 14:28
suspension ?'s xj jak Arizona Chapter 1 April 9th, 2008 13:37
Suspension 101? Mopar500 OEM Tech Discussion 2 October 7th, 2007 22:39
