D.O.S. - PSC Products
Pulley for a stock PS pump? Zip is 93444
PSC Motorsports 95-02 Jeep TJ/XJ/YJ Extreme Duty Cylinder Assist Kit
Designed for Extreme Off Highway driving and 37" and taller tires.
-Provides double the turning force
-Reliefs stress on steering box and frame mounts
-PSC ram assist is the ultimate steering stablizer
Kit includes :
SG061R-N- NEW BIG BORE Cylinder Assist Steering Gear
SP32364JRP- High Performance Pump Kit
SC2207K- (1.75" X 6") Cylinder Kit with Hardware
HK2015- Gear Box to Cylinder Complete Hose Kit Retains use of the factory pressure line and belt.
WARNING!!!! MUST USE A POWER STEERING FLUID COOLER WITH THIS HIGH PERFORMANCE PUMP TO KEEP FROM DAMAGING PUMP.
PSC Motorsports Trail Series 2.5" Double End Steering Cylinder Kit with P-Pump
This kit features the Top selling SC-2212 steering cylinder w/ steering valve that will be 3.5 turns full right turn to full left turn. Also has a SP-1405X pump that is a bolt in replacement for any P-series Saginaw pump that might have been originally installed on a GM, Jeep or Dodge engine. The kit is complete everything you need, even all the hoses. Below is a list of all the items in this list. Other parts can be substituted for items in this kit but note there can be some price differences.
Designed for up to 42" Tall. For 42"-44" Tires order FHK400P
OFFROAD USE ONLY
Part List:
SC2212K- 2.5" X 8" Stroke (Dana 60) Double Ended Steering Cylinder with 2 Clamps (SCCL04)
SC14- Trail Series Clevis Kit with Hardware
TR100- Trail Series Tie rod Kit
FHV-CE120-Eaton Control Valve with -6 An Fittings
FHC04.75-3/4 Round Weld On Stub Steering Column
MB22- Steering Valve Mount Notched for 1.75" Tubing
HK2085- Full Hydraulic Complete Hose Kit
SP1405X- Hi Performance P Style Pump with Remote Can -6 An Pressure -10 An Feed
SR146K-6-10 GEN IV Remote Reservoir Kit with Hoses -6 Pressure -10 Feed
WARNING!!!! MUST USE A POWER STEERING FLUID COOLER WITH HIGH PERFORMANCE STEERING SYSTEMS TO PREVENT PUMP DAMAGE.
Do you carry the PSC PK1851 kit?
I need that and a Derale DER13253 Kit.
