Yukon ZIP Air Locker, Gear Set & Master install kit - $1000 & $100 rebate
RWKHausSupply
For a limited till:
Till September 10th, 2017
You also get a $100 rebate directly back from Yukon!
RWK Haus Supply is offering a Package deal that no one here can even come close to offering...
You get All Yukon Highest Quality parts. Air Locker, Gear set, And complete Master Install Kit.
1 - Yukon Zip Locker is on-demand traction. Its air-operated design allows you to switch from an open differential to 100% lockup when you need it, giving you the ultimate in driver selectability. The Yukon Zip locker is an air operated locker that provides selectable traction for off road or street use. This unit features 4320 Chrome Moly internals for added strength. Assembled in the USA! All Zip Lockers are backed by the best warranty in the business! Yukon covers the replacement unit and covers any collaterally damaged parts and associated labor, up to $2,000 for the first 2 years. And the locker itself comes with a Full Unconditional 6 year Warranty! There are no Limits like the other manufactures set, on Tire Size, Or Engine Size, etc....
2 - Yukon Ring and Pinion gear set in 4.11, 4.56 or 4.88 ratio. Yukon Sets give you the confidence of knowing you're running gears designed for the harshest of conditions. Whether it's on the street, off-road, or at the track; Yukon ring and pinion sets deliver unrivaled performance and quality. Yukon uses the latest designs and manufacturing technologies to provide a quiet running gear that is strong and easy to set up.
3 - Yukon Master Overhaul kit. These kits give you all the high quality parts you need to start and finish every differential job. Yukon offers more tailor-made kits than any other manufacturer in the industry to meet your specific installation needs. Yukon's Master Overhaul kits are the most comprehensive and complete kits on the market. They do extensive research to ensure that every kit is specially tailored to your application. No other kits come as complete as the Yukon. None!
Included are Timken bearings and races along with high quality seals and small parts. Included in this kit are carrier bearings and races, pinion bearings and races, pinion seal, axle seals, complete shim kit, ring gear bolts, pinion nut, oil baffles and slingers , thread locker, marking compound with brush, and gasket.
You get all this:
$1000 for the Dana 30. Or $1050 for the Dana 44
Plus shipping
ALL RWK HAUS SUPPLY ITEMS SHIP SAME DAY AS PAYMENT OR FOLLOWING BUSINESS DAY!
You get your parts Fast. Typically 1-2 days.
This deal is only available via email, call or text.​
Robert
RWK Haus Supply
714-875-2414
Email me - click here
Let me know what exactly you need and I will see what we can do for you.
