Old September 25th, 2003, 16:33
EricT's Avatar
EricT EricT is offline
water pump replacement
ok, so I have all but one of the bolts loose for the water pump pulley. what is the easiest way to get that last bolt loose? no one in town has the spanner wrench. i'd like to get this done today since I have other things on the list that need to get done.
Old September 25th, 2003, 16:41
CW's Avatar
CW CW is offline
I have done it with a strap wrench, and by sticking a long screwdriver in between the studs to keep the pulley from spinning.
Old September 25th, 2003, 17:55
EricT's Avatar
thanks man, I got it
Old September 25th, 2003, 18:52
martin's Avatar
martin martin is offline
EricT,
My one manual gave me a very important tip. When removing the water pump they suggested you break torque on the pulley bolts BEFORE you remove the fan belt. The fan belt will hold the pulley still.
The process is the same tighten them once the pump is attached and the belt it off then torque them to the final value when the belt is installed.
Old September 25th, 2003, 19:08
XJDanny XJDanny is offline
Martin has it right! I've replaced 3 water pumps and never used a spanner wrench. Just loosen the bolts before loosening tension on the belt. Works great. After mounting the pump, you can then torque the pulley bolts to spec after applying correct belt tension. By the way, a Gates Cricket belt tension guage is a great inexpensive tool to monitor correct belt tension. You can get one at your local parts store which carries Gates belts and hoses . Get them to order one for you (~$12) if they don't have one in stock.
Good luck Eric! The job is not too bad and can be done in a couple hours.
Old September 25th, 2003, 21:03
EricT's Avatar
yeah, a couple of hours, if I could get that heater tube loose from the old water pump. I really need a vise
Old September 26th, 2003, 18:01
Wayne Sihler's Avatar
Wayne Sihler Wayne Sihler is offline
No ,you need to go get a new one.You will probably twist it off before it comes out.
Wayne
Wayne
Member#17
NRA Life member, AARP NovaJeepers
96XJ,4.0,AW4,D30/D44,4:10s,Detroit,4.5" lift 33,s
Old September 26th, 2003, 19:54
EricT's Avatar
Talking
thanks, but I got it out. I did not know I could get a new one.
Old September 26th, 2003, 21:33
Anthropy Anthropy is offline
A new heater tube runs about $20. Dealer item only. I you happen to break it, the threads are national pipe and not meteric. That is if you need to come up with a quick solution.
Old September 26th, 2003, 21:37
EricT's Avatar
Talking
thanks, got it on with no problems.....yet
Water Pump failure questions 2xtreme OEM Tech Discussion 2 December 6th, 2003 06:53
Life expectancy of factory water pump? t bell OEM Tech Discussion 16 October 27th, 2003 13:01
Singing water pump??? (long) themud Modified Tech Discussion 0 August 14th, 2003 00:06
Water pump and Thermostat g2z24 OEM Tech Discussion 0 August 9th, 2003 19:14
Which water pump Marc OEM Tech Discussion 2 July 16th, 2003 11:13
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
