Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
Running hp44/9" full width axles on 37x12.50x15 tires--How much lift/b.s. on 8" rims
Running hp44/9" full width axles on 37x12.50x15 tires--How much lift/b.s. on 8" rims?
How much back spacing can U get for 15x8" rims with my full width axles (hp44/9")? Would 4" b.s. work good so it will not be that wide? How much susp lift do I need to clear my 37's. I have 7-8" right now on 35's. Also because I'm going full width and my tires are going to stick out a bit, I'm looking for some Shara TJ flares to cover up my tires. I wasn't running flares with my hp30/44 axles on 35x12.50x15 tires with 8" rims, and it stuck out a bit. Please advise. thanks, Troy |
#2
Re: Running hp44/9" full width axles on 37x12.50x15 tires--How much lift/b.s. on 8" rims
4" bs (assuming that will clear the steering, brakes, etc), leave your lift height.
#3
Thanks Brett, that's what I was thinking. I'm not sure what the b.s. is of my 8" beadlock rims, I'll see how it looks and runs. I know that with a 15" rim, it is hard alot of times to get the larger brakes of the 44 and 9" into the rim so U are forced to run wider than you'd like unless U got with a 16 or 16.5" rim. Do U know how much b.s. U can do with a 10" wide rim, more than 4" b.s.?
Troy |
#4
Do you have the 37's already? (sounds like you do).
If not, go with a 37 on 17" rim. Then go with 5" of bs. It'll easily swallow the brakes, etc. and won't be too wide for northern CA trails. That'd be your best bet. |
#5
15x10s won't let you run any more backspacing than a 15x8, keep to a 15x8 with a 12.50 tire. Half-ton brakes (5 or 6 lug) should fit pretty easily in a 15, it's the 3/4 ton (8 lug) that needs big wheels or little backspacing. I don't know the maximum you can go, but a search here and on Pirate should reveal the answer. you don't want too deep of backspacing or you will bash your hubs on rocks all the time.
with a 65" axle and 4" backspacing you will be about the exact width of mine up front (61.5 wms, 2.5bs 15x10s) which was great on everything except too wide on Winch Hill 3 on Fordyce. |
#6
http://jeep-classifieds.com/classifi...1&from=account Troy |
#7
What did U do on Winch Hill 3, up and over instead of squeezing through? I was at the back of the line and didn't see it when I went with the big group.
Brett, is this where U had trouble on Fordyce with your width? Last edited by Big Red; January 27th, 2005 at 15:44. |
#9
you can see the squeeze in that picture, I was too wide so I tried the left side in that picture and it wasn't working, then I tried the right side (where I'm at in that picture) and that was just a dumb line, but I figured it doesn't hurt to try.
In hindsight, I think I could have swung wider at the right side (left in that picture) and made it. |
#10
What did U end up doing to get beyond that squeeze??? |
#11
that line deserves to be made fun of, it would take a comp buggy to do it.
Thread Tools | |
Display Modes | |
selling old stocker tires and rims off an 01 | Silverstreak01 | Modified Tech Discussion | 2 | September 14th, 2004 14:59 |
31" tires and rims for sale | Kejtar | For Sale: Private Party Only. XJ ITEMS ONLY | 0 | June 21st, 2004 20:45 |
1986 xj with full width axles and more | MTXJ1986 | For Sale: Private Party Only. XJ ITEMS ONLY | 5 | December 4th, 2003 22:31 |
full sizers with 17" rims | gearwhine | Modified Tech Discussion | 14 | October 21st, 2003 19:56 |
Full width axle +/-'s | CW | Modified Tech Discussion | 46 | August 28th, 2003 00:48 |
