Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Grand Cherokee > WK and WK2 Grand Cherokees (2005 - Present)
WK and WK2 Grand Cherokees (2005 - Present) Technical forum focused on the new generation Grand Cherokees.
Old November 17th, 2017, 12:02
burntkat burntkat is offline
NAXJA Member #1145
Re: WK2 air suspension
Originally Posted by shelbyluvv View Post
I will admit I know the answer to my question but I want to see what kind of information will be googled and spit out here. There is a way to lock out the suspension at any speed and to control it with a knob.
This was more to prove my point that this new expansion is not needed. The tech is out there for all these Jeeps.
Sent from my XT1254 using Tapatalk
So basically you're wasting our time. Why should we do anything but waste yours?
Old May 22nd, 2020, 00:35
XJCasper's Avatar
XJCasper XJCasper is offline
NAXJA Member #1042
Have not been on this forum since my son picked my XJ off of me 3 years ago.
Picked up a 2011 WK2 in August.
Bag has a hole in it.
If anyone accidentally opens this post and wants a modern answer?
This is what I am doing. I had no plan to lift this vehicle. My boys talked me into it.
Long story short, I am converting to the Rocky Road Outfitters OME suspension kit. Based on my conversations with RRO, I should have parts about the beginning of July. That is how I will get my lift handled.
Old September 16th, 2022, 09:58
AAubinoe AAubinoe is offline
Hey just renewed my membership after a long absence. Just wanted to post up to add to this discussion.
My 2013 Overland V8 had blown out front struts by 120K miles. Pump was noisy as well. So I removed everything and installed the Rocky road OME kit. All that is really unique about it is the give you the rear coil spring plastic bits that you do not get with the airbags. Still worth it though as they assembly the front struts and the rear shocks and have decent instructions.
the 275-55-R20 tires would NOT clear the Rocky Road HD upper control arms, so I had to install spidertrax spacers. And I have since installed 275-60R20 tires. You absolutely need to cut and fold the pinch weld at the back of each of the front wheel wells. It will cut the tires up.
Overall it is well worth the effort. The air suspension was absolutely fantastic, but the lifespan is about 100K miles. Not worth rebuilding it on a 10 year old Jeep that will inevitable sit more.
Other things that it needed (all original. Easier to do a lot of them with the front suspension removed.
-lower ball joints
-Front wheel bearings and brake shields
-intake and valve cover gaskets
-oil pan (just had a weepy seal, but just decided to put on a whole new pan with a Fumoto valve. The nylon pan has a brass drain insert that is know to break when over tightened. You must drop the crossmember to pull the pan.
-front wheel bearings
-Motor mounts
-02 sensors
-machined exhaust manifolds and installed new gaskets. Also much easier to do with the front crossmember removed. The factory exhaust is still in incredible shape being all stainless steel from the factory.
Air Suspension Lowrange2 South East Chapter 7 December 22nd, 2011 16:05
Air bag suspension old_man Adventure Forum 4 March 2nd, 2010 14:44
Suspension darkoverlift Modified Tech Discussion 4 October 9th, 2009 15:28
suspension ?'s xj jak Arizona Chapter 1 April 9th, 2008 14:37
Suspension 101? Mopar500 OEM Tech Discussion 2 October 7th, 2007 23:39
