misc jeep parts
99NCXJ
Belmont, NC
cleaning out the garage. Here is what i've found so far.
2 xj header pannels. 88ish models one is cracked behind the grill area but either one could be used. 20.00 each
1 xj grill, from 88ish model. has one little fin broke. (about 2-3" missing) 10.00
factory front xj skid. 20.00
stock tj coils from 01 sahara, 4.0L, hardtop.
25.00 per pair
stock tj shocks 20.00 for all 4
stock tj bump stops, 10.00 for all 4
stock xj/tj/mj track bar. 15.00
stock track bar frame mount 10.00
set of 5 canyon wheels with minimal rash, missing one center cap. 200.00
set of 4 savero ht plus tires. 31/10.5/15's 3 have around 75% tread, one has around 50% 100.00 for all 4. (will need to be dismounted from canyons.
one 15 by 8 steel wheel. 6 on 5.5 big center bore. was chrome, has been painted black. Its the round hole design with little allen heads all the way around the "2 part design" look. 20.00
drop in bedliner for long bed comanche (factory) says comanche up under rear cab window. 20.00
xj steering column.from 89 model tilt, with key and wheel. from auto with shift on floor. 30.00
xj steering wheel from 88ish year. good shape. grey. 15.00
3 xj steering boxes. all came off street worthy jeeps. 40.00 each.
one 31/10.5/15 good year mtr with aprox. 90% tread. 100.00
I'll add more as i find it.
all items are up for trade also...just let me know what you have.
also found an xj guage cluster from 89 model. no dummy lights!!! no tach either though.
20.00
also found a stock xj/mj dash clock. I'm pretty sure it works. 15.00 money back if doesn't work.
MJ cab vent covers (behind doors) 20.00 set
rubicon express 3" bump stops for xj 20.00
a few 4.0L ac compressors 20.00 each
AW4 Tranny from 89 xj. 100.00
Neutral safety switch for AW4 tranny. 50.00
class II hitch for xj 25.00
still looking...may find more stuff...
I am going to be in Charlotte the rest of this week for work. It looks like you are only about 20 minutes from there. PM your number and I will come pick it up this week if that works with your schedule.
tried sending a PM on the MJ cab vent covers.. I'll just post it here and PM me when you read this...
Can I get a few pictures of the vents? Front/Back/Side
What are they made of?
LengthXwidthXthickness?
Price including shipping to 51054?
Thanks in advance!
