Go Back   NAXJA Forums -::- North American XJ Association > Bargains and Deals > For Sale: Private Party Only. XJ ITEMS ONLY
For Sale: Private Party Only. XJ ITEMS ONLY Private Party Ads only. If they even smell commercial, they will be deleted.
Old September 3rd, 2008, 16:38
afd516's Avatar
afd516 afd516 is offline
drive shafts axle shafts from wagoneer & xj
Have some spares left over from when I parted out my xj.
The front axle shafts are from a 1982 Wagoneer. Dana 44 driver drop. 82-89 should all be the same with the exception of the 86-87? vacuum disco.
short side shaft $50
long side shafts $75 each
The 2 shorter front drive shafts are from all year xjs. They are stock.
One of them has a conversion joint in it. 1310/1350 free with the shaft.
$30 each.
The long rear drive shaft is for the xj, it has a 1330 cv joints, 1350 yoke to pinion joint. 33" - 35" long, not including cv.
Built by Fort Worth Gera & Axle
$100
817-891-1173
Sam
Edit/Delete Message
Old September 4th, 2008, 10:48
afd516's Avatar
Re: drive shafts axle shafts from wagoneer & xj
one long side shaft and the short side shaft are gone
have all the drive shafts and one long side shaft left
Wanted: Rear Drive Shaft & axle shafts bmanga SEC For Sale / Wanted Forum 12 July 2nd, 2008 19:35
XJ D30 axle shafts - TJ shafts 297X style Tim_MN For Sale: Private Party Only. XJ ITEMS ONLY 0 February 29th, 2008 10:23
Can I drive without my front axle shafts gabe4 Modified Tech Discussion 16 June 27th, 2007 07:30
FS wagoneer and xj dana 44 axle shafts fourwheelerjeff Modified Tech Discussion 3 January 10th, 2006 12:45
I dumped the 86 CV axle shafts for newer 297 TJ axle shafts. DaveB Modified Tech Discussion 1 January 3rd, 2004 06:08
